Conversions |
This property returns an object that allows configuring Command Type Conversions by script. Command Type Conversions are available on the Commands tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing their properties.
NOTE |
Please check topic Conversions for more information about the properties of the object returned by this property. |
