ActiveSource |
Measurement Source used as active by the object. Possible values for this property are the following:
•1: SCADA
•2: Operator (default)
•3: Control Center
•4: Billing
•5: Calculated
•6: Database
•100: Topological Processor
•101: Power Flow
•102: State Estimator
•103: Load Shedding
•104: Distribution Load Modelling
•105: Self-Healing
•106: External Reader
The selected Source type must exist in the Measurement to be set as active. It is not possible to select types 100, 101, 102, 103 , 104, 105, or 106 (Electrical Study outputs) if the StudyInputSource property is set to 0 (ActiveSource). In case the selected Source is deleted, this property assumes a value of 2 (Operator).
