AdviseType |
Controls the Advise mode. The available options are described on the next table.
Available options for the AdviseType property
Option |
Description |
0 - AlwaysInAdvise |
Tag is updated if OPC Block's AllowRead property is set to True and OPC Group's Enable property is also set to True |
1 - AdviseWhenLinked |
Tag is updated only if OPC Block's AllowRead property and OPC Group's Enable property are set to True, and the Tag is associated to an active object, such as a Display on an open Screen or an enabled Alarm, among others. A Tag link for this purpose can be assigned to the following properties: Value, RawValue, Quality, and from Bit00 to Bit31 of OPC Block Elements, and Quality and TimeStamp of OPC Blocks (default) |
Example:
Sub CommandButton3_Click()
MsgBox Application._
GetObject("OPCDriver.OPCGroup.SCRIPT1").AdviseType
