SpinReserveMode
SpinReserveMode
Enum This property allows adjusting the load shedding algorithm's functionality regarding the usage of spinning reserves. Possible values for this property are the following:
0 - MostPowerfulGenerator (default): Uses the spinning reserve of the most powerful generator on the electrical island
1 - IslandGenerators: Uses the sum of spinning reserves of all generators on the electrical island
NOTE
This property is available to electrical models in XPD format, as well as to electrical models in EDB format, and its value cannot be changed while this object is active.
