Terminal1IslandId
Terminal1IslandId
Number This property identifies the island to which the device's Terminal 1 is connected. This is a read-only property and a unique positive integer number for each Scenario. A value of 0 (zero) in this property indicates that there is no information of an available island. A value of -1 (minus one) indicates that this property is not valid for the device or Scenario.
