PrinterName |
Name of the printer used by the Line Printer object. Default value of this property is an empty String, that is, the Line Printer object uses Windows default printer.
NOTES |
•If this property is configured with an empty String and the UseDefaultPrinter property is configured as False, printing is not possible and the PrinterStatus property returns the value 0 (zero, psUnknown). •Windows default printer for the currently logged-in user may be different from the default printer used by E3 Server. This printer is identified by the icon on E3 Admin - Printer window (right-click E3 Admin's icon on Windows Notification Area and select the Printer option). |
