AddField |
AddField([Name], [SourceLink], [Type], [Size])
This method adds a new Historic Field on the Fields object and returns this object. In case of error, this method returns Nothing. All parameters for this method are optional. The next table contains a description for each one of these parameters.
Parameters of the AddField method
Parameter |
Description |
Name |
Historic Field's name. If this parameter is omitted, this name receives the expression "Field" and is auto-incremented, if needed. This parameter corresponds to the Historic Field's Name property. Please check the general Name property for more information about the allowed characters on the names of objects |
SourceLink |
Historic Field's data source. If this parameter is omitted, its data source receives an empty String. This parameter corresponds to the Historic Field's Link property |
Type |
Historic Field's data type. If this parameter is omitted, its data type is configured as 1: Integer. This parameter corresponds to the Historic Field's Type property |
Size |
Historic Field's size. If this parameter is omitted, the Field's size receives the value 0 (zero). This parameter corresponds to the Historic Field's Size property |
NOTE |
For Historic objects whose Database table is created by users, this method returns an error. |
