SummaryDistinctField |
Determines the name of a field used by the selected function in the SummaryFunc property. This property is only valid if the function defined in the SummaryFunc property is from the Distinct Summary function group, which encompasses functions from 9 to 15, and when the SummaryType property is different from 0 (zero).
