AckArea |
AckArea(Area, [ActorID])
Performs an acknowledgment of alarms on a certain Area. This method returns a Boolean indicating whether this operation was successful or not. The Area parameter specifies the name of the Area or Areas whose alarms are acknowledged, by comparing the beginning of their names. For example, AckArea("ANA") acknowledges alarms in Areas "ANALOG", "ANA.AREA2", etc. If this parameter is empty, this method behaves as AckAllAlarms. The ActorID parameter informs the name of the user responsible for acknowledging these alarms. This is an optional parameter and, if omitted, assumes Elipse Power Viewer's logged-on user, "Anonymous" if there is no user logged on, or "System" if this method's call started at the server. Example:
Sub Button1_Click()
'When clicking this button, acknowledges Area1 alarms
Application.GetObject("AlarmServer1")._
AckArea "Area1", Application.User
