ID
ID
Number Unique identifier of a device in the electrical model. This value is usually imported from the electrical model, and cannot be changed at run time. When in the Electrical Modeler, this property is automatically assigned by the system, and it is a read-only property.
NOTE
For electrical model files in XPD format, the value of this property is a Long Integer. For electrical model files in EDB format, on the other hand, the value of this property is a GUID String (such as "{6B29FC40-CA47-1067-B31D-00DD010662DA}"). For devices that do not belong to the electrical model, the value of this property is 0 (zero) in XPD format and "{00000000-0000-0000-0000-000000000000}" in EDB format.
