Shortcut Keys |
For an easy navigation and creation of diagrams, Electrical Modeler provides a series of shortcut keys to some of its tools or to frequently performed operations. The next table contains all shortcut keys available only to models in EDB format.
Shortcut keys to Electrical Modeler tools
Shortcut Key |
Description |
ALT + HOME |
Returns to System level |
ALT + Right arrow |
Goes to the next element in the navigation history |
B |
Inserts a Branch |
BACKSPACE |
Returns to the previous element in the navigation history |
Click the mouse wheel button |
Moves (Pan) the drawing area |
CTRL + Zero (0) |
Fits all objects |
CTRL + A |
Selects all objects |
CTRL + Drag |
Copies the selected objects |
CTRL + Right mouse button |
Area zoom |
CTRL + Rotate mouse wheel |
More or less zoom |
CTRL + Down arrow |
Moves the selected object down (short step) |
CTRL + Left arrow |
Moves the selected object to the left (short step) |
CTRL + Right arrow |
Moves the selected object to the right (short step) |
CTRL + Up arrow |
Moves the selected object up (short step) |
CTRL + Y |
Redoes the last operation |
CTRL + Z |
Undoes the last operation |
DELETE |
Removes the selected objects |
Down arrow |
Moves the selected objects down |
ESC |
Returns to Selection mode |
F11 |
Decrements the StrokeThickness property from the selected or currently edited Substation or Feeder |
F12 |
Increments the StrokeThickness property from the selected or currently edited Substation or Feeder |
F2 |
Edits the name of the selected object(s) |
F7 |
Decrements the size of Description fonts (names of objects) |
F8 |
Increments the size of Description fonts (names of objects) |
J |
Inserts a Jumper |
L |
Inserts a Transmission Line Segment |
Left arrow |
Moves the selected objects to the left |
Right arrow |
Moves the selected objects to the right |
SHIFT + Drag |
Moves the selected objects without complying to grid-defined spacing |
SHIFT + Double-click |
Selects all objects of the type clicked |
SHIFT + Left arrow |
Rotates the selected objects counter-clockwise, in 45-degree steps |
SHIFT + Right arrow |
Rotates the selected objects clockwise, in 45-degree steps |
TAB |
Selects the next element, according to the creation order |
Up arrow |
Moves the selected objects up |
