Power Configuration Object |
The Power Configuration object is essential to applications created in Elipse Power to work. By using this object, users can perform an electrical modeling of a system, as well as use tools to automatically generate an application, regarding data and Screen objects. This object also contains a set of configurations regarding the standardization of Measurement types, Command types, voltage levels, Display colors, and Switch or Breaker colors.
