Gallery |
The Gallery can be accessed by clicking Gallery on the Default toolbar. This item contains a series of vector graphical elements divided into categories, which can be dragged to Screens or to ElipseXs. The available types of symbols are: 3D Pushbuttons, 3D ISA Symbols, Air Conditioning, Architecture, Arrows, ASHRAE (Controls and Equipment), ASHRAE (Ducts), ASHRAE Piping, Basic Shapes, Blowers, Boilers, Buildings, Chemical, Computer Hardware, Computer Keys, Containers, Controllers, Conveyor belts, Conveyor Misc, Conveyor Simple, Ducts, Electrical, Finishing, Flexible Tubing, Flow Meters, Food, General Mfg, Heating, HVAC, Icons and Bitmaps, Industrial Misc, International Symbols, ISA Symbols, Laboratory, Machining, Maps and Flags, Material Handling, Mining, Misc Pipes, Misc Symbols 1, Misc Symbols 2, Mixers, Motors, Nature, Operator Interface, Panels, Pipes, Plant Facilities, Power, Process Cooling, Process Heating, Pulp & Paper, Pumps, Safety, Scales, Segmented Pipes, Sensors, Tank Cutaways, Tanks, Textures, Valves, Vehicles, Water & Wastewater, and Wire & Cable.
To use this feature, follow these procedures:
1.Click Gallery on the Default toolbar.
2.By selecting this window, users have access to sets of symbols, which are grouped in categories. Select a category from the upper side of this window.
3.To insert an object from the symbol Library on a Screen, simply click an object and drag it to the Screen.
4.After inserted, that object can be freely edited and modified, according to the features described for image objects, such as changing the fill color using the OverrideFillMode, OverrideFillColor, or OverrideLineColor properties, with no need to transform the object into an Elipse Power graphical object.
Gallery
