OPC Tag Group
OPC Tag Group
An OPC Tag Group object gathers a series of OPC Tags that share the same update parameters (scan time and dead band). An OPC Tag Group is mandatory to create OPC Tags. To insert an OPC Tag Group, follow this procedure:
1.Right-click an OPC Driver and select the Insert - OPC Tag Group option.
Inserting an OPC Tag Group
Some OPC Tag Group properties can be configured using Properties List, without creating scripts for this. To configure any property, locate it on Properties List and perform the necessary adjustments. For more information on properties, please check the Elipse Power Reference and Scripts Manual.
