User Fields Settings |
The User fields tab allows adding arbitrary values to alarm events.
User fields tab
Available options on the User fields tab
Option |
Description |
Name |
Specifies this Field's name |
Type |
Specifies this Field's type. Available options are 0: String, 1: Integer, 2: Double, or 3: DateTime |
Size |
Specifies this Field's size |
Source |
Specifies this Alarm's data source |
Propagate? |
Forces an immediate update on all alarms that inherit this User Field's value, whenever it receives a forced value or if its Link changes |
Add User Field |
Adds a User Field at the end of this list |
Remove User Field |
Removes the last User Field on this list |
User Fields can only be included or excluded at the end of this list. Excluding User Fields from this list reflects on all Alarm Areas and Sources related to this Alarm Server, but only if the removed Fields were not configured with a forced value or a Link. Otherwise, these Fields still appear on Alarm Areas and Sources. The next figure shows an Analog Alarm with User Fields inherited from an Alarm Server.
Inherited User Fields
NOTE |
For more information about the behavior of a User Field from Alarm Areas and Sources, in Elipse Power Studio and at run time, please check the Link, Value, and ValueSource properties on Elipse Power Reference and Scripts Manual. |
