Simulation of Values
A Data Server is a module responsible for executing and managing Tags and objects that are not directly involved with communication. With a Data Server, users can configure internal and simulation Tags, in addition to insert XObjects, which are data objects from ElipseX libraries. Some objects that can be inserted into a Data Server are described on the next table.
Objects that can be inserted into Data Servers
Object
Description
Counter Tag Counter Tag
Object that performs a time counting, in seconds, up to a pre-determined value, or that performs a certain counting indefinitely
Demo Tag Demo Tag
Object that generates values according to a wave form. It is used to simulate values. It allows generating defined curves or random values
Internal Tag Internal Tag
Generic-purpose object, used to store values of any type, including numbers, texts, and other objects
Timer Tag Timer Tag
Object that performs a time counting and schedules activities. Establishes certain periods of time, with repetitions, to execute actions
Data Folder Data Folder
Defines groups and sub-directories to organize information. New folders can be inserted inside others, if needed
NOTE
Objects inserted in a Data Server are executed by an E3 Server, therefore they are present in that Server. This information shows how Elipse Power works.
