XFolder |
An XFolder is a server object that allows organizing or creating a hierarchy of objects in the instances created. Objects that can be inserted in an XFolder instance are Data Folders, I/O Tags, Queries, Alarm Filters, XFolder and XObject instances, and Alarms.
NOTE |
Users are not allowed to insert objects in an XFolder definition, only in its instances. |
