Storage
Storage
Let's create a Storage object and configure it to store system information. After that, let's add information to store, which are the variables referring to the position of Breakers and Switches and Transformer's oil temperature.
1.Insert a Storage object in the project Elipse_Power_Tutorial.prj. To do this, select the Insert Storage in option of the contextual menu on the Server objects - Databases item.
Option to insert a Storage in a project
2.Change this object's name to "StoragePower".
3.In the StoragePower object, insert a Field and select the Value property of Measurement BreakerPosition of Breaker 52-01 on Substation SE1. This configuration must be performed as follows:
Source: SE1.[52-01].Measurements.BreakerPosition.Value
Type: 3 - eStorageInteger
Storage Field
Storage Field
4.Repeat the previous step for other Discrete Measurements to store on the database.
5.Now let's configure an information about Transformer's oil temperature to store. Let's add a new Field in the Storage, pointing to this Measurement:
Source: SE1.[TR-01].Measurements.OilTemperature.Value
Type: 0 - eStorageDouble
Dead Band: 5
Unit: 0 - dbPercent
6.Repeat the previous step for other Analog Measurements to store on the database.
7.Open the Properties Window of the StoragePower object and configure the following options on the Storage tab with the following values:
Database Server: DB1, using AppBrowser
Table name: PowerMeasurements
Storage tab
Storage tab
8.Click Create Table. The window displayed on the next figure must appear.
Structure successfully created
