Exercises
Exercises
In this exercise, let's configure an IEC 61850 Driver to communicate with Infotech's IEC61850 Server Simulator, and also perform links from data objects to the provided variables. To simulate commands, the Simulator contains two switches, one of type DO (Direct Operate) and another one of type SBO (Select Before Operate), which are both supervised and controlled by the application.
NOTE
To perform this exercise, Infotech's IEC61850 Server Simulator must be in execution. This Simulator is available at Infotech's website.
