E3Alarm |
An E3Alarm is a tool for monitoring active or unacknowledged Alarms in an application. By using this object, users can verify Alarm statuses, as well as acknowledge them manually. To use this object, right-click the working area and then select the Insert - E3Alarm option.
E3Alarm
The Connections tab of E3Alarm Properties Window specifies information regarding an Alarm Server or Servers and the Filters tab specifies Filters by area or customized.
