Configuring a Section Report |
By using this option, users can configure specifications of a Section Report, such as page, printing, and styles. The next figure shows the Page Setup tab for a Section Report.
Page Setup tab
Available options for the Page Setup tab
Option |
Description |
Top margin |
Specifies the margin for the top of a page |
Bottom margin |
Specifies the margin for the bottom of a page |
Left margin |
Specifies the left margin of a page |
Right margin |
Specifies the right margin of a page |
Gutter |
Specifies a page margin |
Mirror margins |
Enables or disables a mirrored margin of a page |
The next figure shows the Printer Settings tab of a Section Report.
Available options for the Printer Settings tab
Option |
Description |
Paper Size |
Specifies the size of a paper |
Width |
Specifies the width of a paper |
Height |
Specifies the height of a paper |
Orientation |
Specifies a paper orientation in a printer. The available options are Printer Default: Settings according to a default printer, Portrait: Vertical page layout, or Landscape: Horizontal page layout |
Collate |
Sorts the printing process |
Duplex |
Duplicates the printing process |
Paper Source |
Specifies settings and type of paper for the printing process |
The next figure shows the Styles tab of a Section Report.
Styles tab
Available options for the Styles tab
Option |
Description |
New |
Creates a new style |
Delete |
Deletes the selected style |
Export styles to file |
Exports all styles to a file with the .reportstyle extension |
Import styles from file |
Import the styles from a file saved using the Export styles to file option |
Font name |
Selects a font for the selected style |
Font size |
Selects a font size for the selected style |
Bold |
Applies a bold effect to the selected style |
Italic |
Applies an italic effect to the selected style |
Underline |
Applies an underline effect to the selected style |
Strikethrough |
Applies a strike-through effect to the selected style |
BackColor |
Selects a background color for the selected style |
ForeColor |
Selects a color for the text of the selected style |
Horizontal Alignment |
Selects a horizontal alignment for the text of the selected style. The available options are Left (default), Center, Right, or Justify |
Vertical Alignment |
Selects a vertical alignment for the text of the selected style. The available options are Top (default), Center, or Bottom |
Script |
Selects a type of font script for the selected style |
NOTE |
Importing a style file from a Section Report implies in overwriting all configured styles. |
The Global Settings tab determines general settings for the drawing area.
Global Settings tab
Available options on the Global Settings tab
Option |
Description |
Snap Lines |
Allows using snap lines or not to align controls |
Snap to Grid |
Indicates whether controls move from a snap line to another one when aligning or not |
Show Grid |
Shows or hides the grid |
Grid Columns |
Number of grid columns |
Grid Rows |
Number of grid rows |
Grid Mode |
Grid's view mode. The available options are Dots: Shows the grid as dots or Lines: Shows the grid as lines |
Dimension lines |
Determines whether dimensions must be shown or not when resizing an object |
Show Delete Prompt |
Select this option to show a warning message when deleting a parameter or calculated field |
Ruler Units |
Determines the type of unit of the ruler. The available options are Inches or Centimeters |
Preview Pages |
Determines the number of pages to show when selecting the Preview |
