Licenses |
Elipse Software provides two playback packages, according to its tools:
•Basic Playback
•Advanced Playback: This is a Basic Playback plus Video Recording and Screen Capture tools
Each one of these packages is dimensioned according to the number of points (Tags and Alarm Sources) stored on a database. For example, a Basic Playback 1000 allows performing a playback on a database with up to 1,000 points. If a database contains more points than the available licenses, a database assembling process fails and an error message is then displayed, indicating that there are no available licenses to execute playback.
An Elipse Power Studio license includes an Advanced Playback license with no limit on points, although it is limited to the last six hours of data stored on a database. This allows an application developer to test playback without purchasing licenses for this.
In Demo mode (when there is no protection device), playback also works in Advanced mode without a limitation on points, although limited to display only the last six hours of data stored on a database, relative to the current server time.
IMPORTANT |
If a protection device is a Master- (Elipse Power Studio + Runtime) or Runtime only-type, playback is only available if there are licenses programmed on this protection device. For more information about limitations of Elipse Power's Demo mode, please check topic Limitations of Demonstration Mode. |
