Item, Position, and General Tabs
On the Item tab, users can view the name of an object and assign a description to it.
Item tab
Item tab
Each option on the Item tab has a corresponding property. The available options on this tab are described on the next table.
Available options on the Item tab
Option
Description
Name
Determines this object's name. This option is equivalent to E3Chart's Name property
Documentation
A free text that enables documenting this object's features and functionality by a developer. This option is equivalent to E3Chart's DocString property
The Position tab specifies an E3Chart's position on a Screen.
Position tab
Position tab
Each option on the Position tab has an equivalent property. The available options on this tab are described on the next table.
Available options on the Position tab
Option
Description
X
Defines this object's left horizontal coordinate, in Himetric units. This option is equivalent to E3Chart's X property
Y
Defines this object's upper vertical coordinate, in Himetric units. This option is equivalent to E3Chart's Y property
Width
Determines this object's width. This option is equivalent to E3Chart's Width property
Height
Determines this object's height. This option is equivalent to E3Chart's Height property
On the General tab, users can specify E3Chart's style and appearance.
General tab
General tab
Each option on the General tab has a corresponding property. The available options on this tab are described on the next table.
Available options on the General tab
Option
Description
Show title
Displays this chart's title. This option is equivalent to E3Chart's Title property
Show title with color
Determines a color for the text of this chart's title. This option is equivalent to E3Chart's TitleColor property
Show border
Enables or disables an external border on this E3Chart, when the visualization of scales is disabled. This option is equivalent to E3Chart's ShowBorder property
Paint the chart's background with
Determines this chart's background color. This option is equivalent to E3Chart's BackColor property
Paint the grid's background with
Determines a background color for the grid. This option is equivalent to E3Chart's GridBkColor property
Refresh rate (seconds)
Determines an interval between drawing updates in this chart. This option is equivalent to E3Chart's RefreshTime property
