OPC Server |
In addition to an OPC Client (OPC Driver), Elipse Power also works as an OPC DA (Data Access) Server 2.0x. This allows Elipse Power to expose all existing objects in the executing Domain, such as I/O Tags, to applications external to Elipse Power. Some examples are Elipse SCADA, Elipse Power, which can be executing on another application as a Client, or an OPC Client from another manufacturer, as long as this Client implements the OPC DA 2.0x standard or later.
NOTE |
Elipse Power's OPC Server is an additional module since version 3.0, and it needs a specific license on a protection device. Please contact Elipse Software for more information. |
