Version 1.6
Version 1.6
New Features
•New Icons: The border of the controls is now rounded.
•Page Link Control Size Customization
•"Go Offline" Button Hidden
•Search Functionality Implemented
•Added External Authentication Option Using OAuth/OpenID
•Send Messages via Telegram in Events
•New Functions to Check Quality Added on the Server
•Global Email Configuration Used When Application Configuration is Empty
•Updated Native Connection Library with E3, Allowing Encryption Options on the E3 Server
•Remote Connection with Arduino Removed
•Logging for Tag Writing When Performed by Pulse Control
•New Property to Configure Digital Type Drawing in Chart and MiniTrend
•Removed File Import Code from Versions Prior to 1236
•Implemented Two-Factor Authentication for Increased User Security
•Improved Performance for Reading Large Configuration Files
•Added Option to Customize Images and Text During PWA Installation
•Internal Tags Can Now Have Custom Names in Demo Connection
•Added Button to Update Client on the "About" Page
•Email Field Now Mandatory When Editing or Adding a User
•Added HEAD Method to HTTP Protocol
•Updated e3connection Library Version to 660294
•Default Value of the Property 'securityversion' Changed to 4 (TLS 12 and Above)
•Included X-Frame-Options Header in HTTP Protocol
•Page Title Now Adjusted According to the Configured Short Name
•Adjusted Title Alignment in Chart
•Connection Passwords No Longer Displayed Directly
Bug Fixes
•Fixed Image Upload Preview Issue
•Fixed "User Exceeded" Message Issue
•Mobile Now Reads UTF-8 Files with or without BOM Without Errors
•Fixed Tag Writing Issue with Double and String Values in CloudLink Connection
•General Review of Escape Sequence Conversion, Fixing String Issues in CloudLink and Other Connections
•Fixed Events Not Returning After E3 Crash
•Fixed Installer Issue Not Detecting Open Administrator
•Changed Base and Positive Value Names, Which Were Reversed in Pulse
•Fixed Title/Legend and Scale Overlap Issue
