ValueOf |
ValueOf(TagName)
Returns the value of a Tag. The TagName parameter is the name of a Tag. The return data type of this function can be String, number, Boolean, or null. The next code contains an example of using this function.
var tagValue = ValueOf("demo:TagInternal1");
