<< Click to Display Table of Contents >> Commands |
A Commands Control allows creating a list of commands to execute according to a previous condition. Commands can also be interlocked based on a condition from the reading Tag. The condition and the command are performed on different Tags. To use it, configure the options described on the next table.
Available options for Commands
Option |
Description |
Title |
Visible text on top of the Commands |
Subtitle |
Visible text below Commands' title |
Color |
Commands' color. Click |
Image |
Image viewed near the value of a Commands Control. Click |
Zones |
List of zones of a Commands Control. For more information, please check topic Zones |
Commands |
List of commands of a Commands Control. For more information, please check topic Commands |
Interlocked |
Expression informing when commands cannot be used. When this expression is evaluated as true, commands are blocked. When this expression is evaluated as false, commands are allowed |
Require confirmation before change |
Enables a confirmation for a value before writing |
Tag Read |
Tag used to receive a writing return. Click |
Tag Write |
Tag used to write a value. Click |
