SCADA |
A SCADA
Connection creates a connection to an Elipse SCADA server via OPC DA. To do so, select the Connections
tab, click Add
, and select the SCADA option. The window on the next figure is opened.
SCADA Connection
Available options for a SCADA-type of Connection
Option |
Description |
Name |
Connection's name |
Server |
Indicates the type of connection to an Elipse SCADA server, local to use Elipse SCADA from the local computer or other to indicate an Elipse SCADA server on the network |
NOTE |
This Connection is only available for the Elipse Mobile On-Premises version of Elipse Mobile Server. |
