E3 (OPC DA) |
An E3 (OPC DA)
Connection creates a connection to an E3 or Elipse Power server via OPC DA. To do so, select the Connections
tab, click Add
, and select the E3 (OPC-DA) option. The window on the next figure is opened.
E3 (OPC DA) Connection
Available options for an E3 (OPC DA)-type of Connection
Option |
Description |
Name |
Connection's name |
Server |
Indicates the type of connection to an E3 or Elipse Power server, local to use E3 via OPC DA from the local computer or other to indicate an E3 or Elipse Power server via OPC DA on the network |
NOTE |
This Connection is only available for the Elipse Mobile On-Premises version of Elipse Mobile Server. |
