Customization
Customization
To customize the application, go to the Settings menu and then click on Personalization.
Name, Short Name, Description
The properties Name, Short Name, and Description are used to describe the application during PWA installation. The Short Name property also serves as the title that appears on the browser tab.
Icons
To generate the icons, it is recommended to submit an image of 512x512 pixels. The server automatically resizes the image to create smaller versions. These images will be used in the PWA installation and also as the application icon.
Login Image
The login image is the one that appears at the start of the application and can be customized by uploading a new image that should be approximately 238x61 pixels.
NOTA
For the customization changes to take effect, it is necessary to refresh the application in the browser by pressing Ctrl+F5.
