Server
Server
Added the Connection Security and Authentication Method options on the configurations of SMTP server.
Added an example Form on the demonstration application.
Create a new Form application with an example of inspecting telecommunication towers.
Now users can inform an e-mail to sysadmin and the server uses that e-mail to send information about the system for that general administrator. Also created a configuration to send e-mails separately.
Updated the OpenSSL library to version 1.1.1d and the E3Connection library to version 5.5.79.
Updated the script to generate a self-signed certificate.
Improvements on HTTPS performance and increased the time-out of Keep Alive from 5s to 50s.
Added an option to test e-mail configuration.
Removed the Arduino via Serial-type of connection.
Starting with version 1.5.163, the server now blocks connections from clients with versions equal or previous to version 1.5.155.
Now all Trend-type Tags are activated during server initialization.
