Toggle |
A Toggle
is a Control that allows performing persistent writings of two values to a Tag. To use it, configure the options described on the next table.
Available options for a Toggle
Option |
Description |
Title |
Visible text on top of the Toggle |
Subtitle |
Visible text below Toggle's title |
Color |
Toggle's color. Click |
Tag |
Tag used to perform readings and writings of a value by a Toggle. Click |
Require confirmation before change |
Enables a confirmation for a value before writing it |
ON - Value |
A value interpreted as True |
ON - Text |
Text viewed when the value is True |
ON - Image |
Image viewed when the value is True. Click |
OFF - Value |
A value interpreted as False |
OFF - Text |
Text viewed when the value is False |
OFF - Image |
Image viewed when the value is False. Click |
