Setpoint |
A Setpoint
allows performing writings of values to a Tag. That writing can be performed by writing a value directly to the value's field or by using the increment
or decrement
options. To use it, configure the options described on the next table.
Available options for a Setpoint
Option |
Description |
Title |
Visible text on top of the Setpoint |
Subtitle |
Visible text below Setpoint's title |
Color |
Setpoint's color. Click |
Image |
Image viewed near a Setpoint's value. Click |
Tag |
Tag used to perform readings and writings of a value by a Setpoint. Click |
Increment |
Increment value if users opt to select a value using this option |
Require confirmation before change |
Enables a confirmation for the value before writing it |
Suffix |
Text visible near a Tag's value |
Decimals |
Number of decimal places of a Tag's value |
Write As |
Writing data type of a Tag's value. The available options are Text and Number |
