Pulser |
A Pulser
is a Control that allows performing writings when a base condition is met. That writing is performed to a Tag and its result or verification of the base value is returned through another Tag. To use it, configure the options described on the next table.
Available options for a Pulser
Option |
Description |
Title |
Visible text on top of the Pulser |
Subtitle |
Visible text below Pulser's title |
Color |
Pulser's color. Click |
Tag Read |
Tag used to receive a writing's return. Click |
ON - Value |
A value interpreted as True |
ON - Text |
Text viewed when the value is True |
ON - Image |
Image viewed when the value is True. Click |
OFF - Value |
A value interpreted as False |
OFF - Text |
Text viewed when the value is False |
OFF - Image |
Image viewed when the value is False. Click |
Tag Write |
Tag used to write a value. Click |
Value base |
Condition where a reading Tag must be so that a Pulser writes the value in the Value Positive option |
Value Positive |
A value to write if the reading Tag contains the same value configured in the Value base option |
Require confirmation before change |
Enables a confirmation for a value before writing it |
