Browsers |
Although Elipse Mobile is developed for mobile applications, users can access an application via browser by using an address in the format http://server_ip:port/, such as http://127.0.0.1:8080/. Users can also access an application by using the name of a server machine on the network, such as http://localhost:8080/.
NOTE |
Default TCP/IP port used by Elipse Mobile is 8080. To change this configuration, please check topic Server Settings. |
