Proxy Settings |
Manual configuration of a proxy is needed when an internal network uses a proxy server. To do so, click Advanced on the main window of Elipse CloudLink, select the Manual configuration option, and then type an address and a username and a password if the proxy server needs authentication. In its current version, Elipse CloudLink only executes Basic Authentication-type authentications. If there are problems when configuring a proxy, please contact us at suporte@elipse.com.br.
Proxy settings
