Settings of an E3 Connection |
If the E3 or Elipse Power server is executing on another computer, click Settings on the main window of Elipse CloudLink to configure this connection.
On this window, select the Network option and type a path to the server in the same format used for Viewer. If needed, inform a username and a password for connection.
NOTE |
If a username and a password are not provided, Elipse CloudLink connects to the E3 server using the user currently logged on Windows. |
By default, Elipse CloudLink does not allow writing to Tags. If users must enable writing, select the Enable Write option.
