OPC DA |
An OPC DA
Connection creates a connection to a server that uses OPC DA technology. To do so, select the Connections
tab, click Add
, and select the OPC-DA option. The window on the next figure is opened.
OPC DA Connection
Available options for an OPC DA-type of Connection
Option |
Description |
Name |
Connection's name |
OPC Server program ID |
OPC DA's server identification |
Server |
Indicates the type of connection to an OPC DA server, local to use an OPC DA server from the local machine or other to indicate an OPC DA server on the network |
NOTE |
This Connection is only available for the Elipse Mobile On-Premises version of Elipse Mobile Server. |
