E3
E3
An E3 E3 Connection Connection creates a native connection to an E3 or Elipse Power server. In this type of Connection, the system administrator can add two servers (Hot-Standby) so that, in case the main server fails, the backup server is activated and Elipse Mobile can use this server. The names of these servers must be separated by commas. To do so, select the Connections Connections tab, click Add Add, and select the E3 option. The window on the next figure is opened.
E3 Connection
E3 Connection
Available options for an E3-type of Connection
Option
Description
Name
Connection's name
Server
Indicates the type of connection to an E3 or Elipse Power server, local to use E3 from the local machine or other to indicate an E3 or Elipse Power server on the network
User
Name of a user on the E3 or Elipse Power server
Password
Password of a user on the E3 or Elipse Power server
NOTES
•In case of E3 or Elipse Power servers in Hot-Standby mode, select the other item in the Server option and indicate the servers participating in the Hot-Standby mode separated by commas, such as "\\SERVER1,\\SERVER2".
•This Connection is only available for the Elipse Mobile On-Premises version of Elipse Mobile Server.
