Backing Up an Application |
Each application is stored on a folder with the same name of the application on the Projects folder of Elipse Mobile installation directory. That folder contains a configuration file and a medias folder containing images used on the application.
To perform a backup of an application, copy the corresponding folder to another directory. That folder can be placed on the Projects folder of another Elipse Mobile. Users can also copy only the medias folder from one application to another.
