Customizing Images |
To customize the login image of PWA (Progressive Web App) and Web Applications, load an image called "elipse-horizontal-logo.png" to anyu control that contains an image. This image must be sized 210 pixels of width and 45 pixels of height.
This image is stored on the medias folder of the Application, such as C:\Program Files (x86)\Elipse Software\Elipse Mobile Server\Projects\Demo\medias. If users have access to Application's installation folder, this image can be placed there manually.
NOTE |
The login image of an Application in the store of its respective operating system cannot be customized. Also, customizing the login image is not available in Demo mode. |
This configuration must be performed directly on the Application's installation folder, there is no way to perform it online. To do so, change the icons on the resources folder, such as C:\Program Files (x86)\Elipse Software\Elipse Mobile Server\Projects\Demo\resources.
NOTE |
Do not change the name or dimensions of icons on the resources folder. |
An Application is created with the suggested name during installation. If users want to change that name, locate the file manifest.json on the Application's installation folder, such as C:\Program Files (x86)\Elipse Software\Elipse Mobile Server\Projects\Demo\manifest.json, and change the name and short_name items to the new name and short name, respectively.
