EpmQueryAggregateFunction
Returns data from one or more variables, comma-separated, informed in the @node parameter, according to the format defined by the aggregation function indicated by the @aggregateFunction parameter.
Syntax
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(@timeZoneOffset, @startTime, @endTime, @sampleInterval, @aggregateFunction, @node)
Parameters
•@timeZoneOffset: Timezone to consider. Possible values range between -12 and 14
•@startTime: Initial date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@endTime: Final date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@sampleInterval: Time interval used to calculate aggregation, in milliseconds
•@aggregateFunction: Name of the aggregation function to use. Possible values for this parameter are described on the next table
•@node: Variable or variables to query. Users must inform the full name or names between single quotes and comma-separated
Possible values for the @aggregateFunction parameter
Value
Description
AnnotationCount
Returns the total number of Annotations in the sampling interval defined in the @sampleInterval parameter
Average
Calculates the average of stored raw values with a good quality in the sampling interval defined in the @sampleInterval parameter
Count
Returns the total number of stored raw values with a good quality in the sampling interval defined in the @sampleInterval parameter
Delta
Returns the difference between the first and last raw value in the sampling interval defined in the @sampleInterval parameter with a good quality. Corresponds to the result of calculating @endTime – @startTime
DeltaBounds
Returns the difference between the value with a good quality of the beginning and ending of the sampling interval defined in the @sampleInterval parameter. Corresponds to the result of calculating EndBounds – StartBounds
DurationBad
Returns the time, in milliseconds, in which data had a bad quality in the sampling interval defined in the @sampleInterval parameter. Quality is defined based on the quality of data from this interval's limits
DurationGood
Returns the time, in milliseconds, in which data had a good quality in the sampling interval defined in the @sampleInterval parameter. Quality is defined based on the quality of data from this interval's limits
DurationInStateNonZero
Returns the elapsed time, in milliseconds, in which the status of a value with a good quality was different from 0 (zero) in the sampling interval defined in the @sampleInterval parameter
DurationInStateZero
Returns the elapsed time, in milliseconds, in which the status of a value with a good quality was 0 (zero) in the sampling interval defined in the @sampleInterval parameter
End
Returns the last raw value with a good quality in the sampling interval defined in the @sampleInterval parameter with the timestamp in which it occurred
EndBounds
Returns the value with a good quality from the end of the sampling interval defined in the @sampleInterval parameter
Interpolative
Interpolates the consecutive points of data with a good quality of the sampling interval in the @sampleInterval parameter. For discrete variables, the interpolation only keeps the previous value up to the next one, while for continuous variables the interpolation between two consecutive points is linear
Maximum
Equivalent to the MaximumActualTime value, but uses the timestamp of the beginning of the sampling interval in the @sampleInterval parameter instead of when the value effectively occurred
Maximum2
Equivalent to the MaximumActualTime2 value, but uses the timestamp of the beginning of the sampling interval defined in the @sampleInterval parameter instead of when the value effectively occurred
MaximumActualTime
Returns the greatest raw value with a good quality in the sampling interval defined in the @sampleInterval parameter, using the timestamp of when the value itself occurred
MaximumActualTime2
Returns the greatest value according to data linearly interpolated in the sampling interval defined in the @sampleInterval parameter
Minimum
Equivalent to the MinimumActualTime value, but uses the timestamp of the beginning of the sampling interval defined in the @sampleInterval parameter instead of when the value effectively occurred
Minimum2
Equivalent to the MinimumActualTime2 value, but uses the timestamp of the beginning of the sampling interval defined in the @sampleInterval parameter instead of when the value effectively occurred
MinimumActualTime
Returns the smallest raw value with a good quality in the sampling interval defined in the @sampleInterval parameter, using the timestamp of when the value itself occurred
MinimumActualTime2
Returns the smallest value according to data linearly interpolated in the sampling interval defined in the @sampleInterval parameter
NumberOfTransitions
Returns the total number of transitions of a raw value with a good quality from a variable in the sampling interval defined in the @sampleInterval parameter
PercentBad
Returns the result of calculating (DurationBad ÷ @sampleInterval) × 100
PercentGood
Returns the result of calculating (DurationGood ÷ @sampleInterval) × 100
PercentInStateNonZero
Returns the result of calculating (DurationInStateNonZero ÷ @sampleInterval) × 100
PercentInStateZero
Returns the result of calculating (DurationInStateZero ÷ @sampleInterval) × 100
Range
Returns the difference between the maximum and minimum raw value with a good quality in the sampling interval defined in the @sampleInterval parameter. If there is only one value with a good quality in that interval, returns the value 0 (zero)
Range2
Returns the difference between the greatest and the smallest value according to the linearly interpolated data in the sampling interval defined in the @sampleInterval parameter
StandardDeviationPopulation
Returns the population standard deviation in the sampling interval defined in the @sampleInterval parameter
StandardDeviationSample
Returns the sample standard deviation in the sampling interval defined in the @sampleInterval parameter
Start
Returns the first raw value with a good quality in the sampling interval defined in the @sampleInterval parameter with the timestamp in which it occurred
StartBounds
Returns the value with a good quality from the beginning of the sampling interval defined in the @sampleInterval parameter
TimeAverage
Calculates the weighted average by time, using data with a good quality linearly interpolated in the sampling interval defined in the @sampleInterval parameter
TimeAverage2
Calculates the weighted average by time, using interpolated data keeping the previous value up to the next one, in the sampling interval defined in the @sampleInterval parameter
Total
Returns the result of calculating TimeAverage × @sampleInterval, in seconds
Total2
Returns the result of calculating TimeAverage2 × @sampleInterval, in seconds
Trend
Automatically Interpolates data in the sampling interval defined in the @sampleInterval parameter, prioritizing quality for chart viewing according to a given screen resolution
VariancePopulation
Returns the population variance, that is, the square root of the population standard deviation in the sampling interval defined in the @sampleInterval parameter
VarianceSample
Returns the sample variance, that is, the square root of the sample standard deviation in the sampling interval defined in the @sampleInterval parameter
WorstQuality
Returns the worst quality of raw data in the sampling interval defined in the @sampleInterval parameter. A Bad quality is worst than Uncertain, which by its turn is worst than Good. Timestamp always corresponds to the beginning of this interval
WorstQuality2
Returns the worst quality of raw data in the sampling interval defined in the @sampleInterval parameter. A Bad quality is worst than Uncertain, which by its turn is worst than Good. The beginning of this interval is always included to determine the worst quality. Timestamp always corresponds to the beginning of this interval
Resulting Fields
•Name: Name of the variable or variables queried
•Timestamp: Timestamp of data
•Quality: Quality of data
•Value: Value of data
Usage Example
To return data from variable RandomTags_Random1 in the period between 10:23 and 11:23 on 12/07/2020, with a timezone of -3 (minus three) hours and interpolated at every 5 (five) minutes, use the next declaration.
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(-3, '2020-12-07 10:23:00', '2020-12-07 11:23:00', 300000, 'Interpolative', 'RandomTags1')
