EpmBrowseTypeInstancesFunction |
Returns a table with a list of all items found on the Elipse Data Model or EPM Model tree with the type informed in the @typeName parameter.
SELECT * FROM EpmBrowseTypeInstancesFunction(@typeName)
•@typeName: A String representing the type or class of the items to query. This value must be informed between single quotes
•InstancePath: Full path of the items found
To return all items whose type is equal to "Room" on paths containing the expression "[Elipse-RS]", use the next declaration.
SELECT * FROM EpmBrowseTypeInstancesFunction('Room') WHERE InstancePath LIKE '%[Elipse-RS]%'
