EpmQueryAggregateFunction
Returns data from one or more variables, comma-separated, informed in the @node parameter, according to the format defined by the aggregation function informed in the @aggregateFunction parameter.
Syntax
SELECT Name, Timestamp, Quality, <type_function>(Value)
  FROM EpmQueryAggregateFunction(<[float]@timeZoneOffset>,
  <[datetime]@startTime>, <[datetime]@endTime>, <[bigint]@sampleInterval>,
  <[string]@aggregateFunction>, <[string]@node>)
Parameters
<type_function>: Conversion function to define a data type for the resulting values on the Value column. Possible values are described on topic EpmReadPropertyFunction
<[float]@timeZoneOffset: Timezone to consider. Possible values range from -12 to 14
<[datetime]@startTime>: Initial date of the period to retrieve. This must be a String in the format yyyy-MM-dd HH:mm:ss
<[datetime]@endTime>: Final date of the period to retrieve. This must be a String in the format yyyy-MM-dd HH:mm:ss
<[bigint]@sampleInterval>: Time interval to use when calculating the aggregation, in milliseconds
<[string]@aggregateFunction>: Name of an aggregation function to use. Possible values for this parameter are:
Trend: Interpolates data for a better visualization on charts
Interpolative: Interpolates data in the informed interval, returning points as defined in the @sampleInterval parameter
Start: Equivalent to the Interpolative function, but uses the original timestamp of the first value of the sampling interval
End: Equivalent to the Interpolative function, but uses the original timestamp of the last value of the sampling interval
StartBounds: Equivalent to the Interpolative function, but uses the original timestamp of the first value of the sampling interval. It considers the Simple Bounding Values
EndBounds: Equivalent to the Interpolative function, but uses the original timestamp of the last value of the sampling interval. It considers the Simple Bounding Values
Average: Calculates the average of data values with good quality in the sampling interval defined in the @sampleInterval parameter
TimeAverage: Calculates the average weighted by time using the Interpolated Bounding Values method in the sampling interval defined in the @sampleInterval parameter
TimeAverage2: Calculates the average weighted by time using the Simple Bounding Values method in the sampling interval defined in the @sampleInterval parameter
Total: Returns the sum of data from the sampling interval defined in the @sampleInterval parameter
Total2: Returns the sum of data with good quality from the sampling interval defined in the @sampleInterval parameter
Count: Returns the number of data available in the sampling interval defined in the @sampleInterval parameter
Minimum: Informs the minimum value found on data in the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the initial time of each sampling interval
Maximum: Informs the maximum value found on data in the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the initial time of each sampling interval
MinimumActualTime: Informs the minimum value found on data in the sampling interval defined in the @sampleInterval parameter, except that the timestamp displayed corresponds to the moment of the occurrence of the minimum value found
MaximumActualTime: Informs the maximum value found on data in the sampling interval defined in the @sampleInterval parameter, except that the timestamp displayed corresponds to the moment of the occurrence of the maximum value found
Range: Returns the difference between the minimum and maximum value found in the sampling interval defined in the @sampleInterval parameter. It ignores values with a bad quality
Minimum2: Informs the minimum value found on data in the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the initial time of each sampling interval. It considers the Simple Bounding Values
Maximum2: Informs the maximum value found on data in the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the initial time of each sampling interval. It considers the Simple Bounding Values
MinimumActualTime2: Informs the minimum value found on data in the sampling interval defined in the @sampleInterval parameter, except that the timestamp displayed corresponds to the moment of the occurrence of the minimum value found. It considers the Simple Bounding Values
MaximumActualTime2: Informs the maximum value found on data in the sampling interval defined in the @sampleInterval parameter, except that the timestamp displayed corresponds to the moment of the occurrence of the maximum value found. It considers the Simple Bounding Values
Range2: Returns the difference between the minimum and maximum value found in the sampling interval informed in the @sampleInterval parameter. Ignores values with bad quality and considers the Simple Bounding Values
Delta: Returns the difference between the first and last values with good quality in each sampling interval
DeltaBounds: Returns the difference between the first and last values with good quality in the sampling interval. It considers the Simple Bounding Values
AnnotationCount: Informs the number of annotations a variable has in the sampling interval
DurationInStateZero: Returns the total time, in milliseconds, in which a value was equal to 0 (zero) in the sampling interval
DurationInStateNonZero: Returns the total time, in milliseconds, in which a value was different from 0 (zero) in the sampling interval
PercentInStateZero: Returns the time percentage, relative to the total time of the sampling interval, in which a value was equal to 0 (zero)
PercentInStateNonZero: Returns the time percentage, relative to the total time of the sampling interval, in which a value was different from 0 (zero)
NumberOfTransitions: Informs how many transitions occurred in the sampling interval between values  0 (zero) and 1 (one)
DurationGood: Returns the time, in milliseconds, in which data was with good quality in the sampling interval. Quality is based on the quality of data from interval's boundaries
DurationBad: Returns the time, in milliseconds, in which data was with bad quality in the sampling interval. Quality is based on the quality of data from interval's boundaries
PercentGood: Returns a time percentage, relative to the time of the sampling interval, in which data had good quality
PercentBad: Returns a time percentage, relative to the time of the sampling interval, in which data had bad quality
WorstQuality: Returns the worst quality in the interval specified in the @sampleInterval parameter
WorstQuality2: Returns the worst quality found in the interval specified in the @sampleInterval parameter. It considers the Simple Bounding Values
StandardDeviationPopulation: Returns the standard population deviation (n) in the requested interval. It considers the Simple Bounding Values
VariancePopulation: Returns the variance for the StandardDeviationPopulation function
StandardDeviationSample: Returns the standard sampling deviation (n - 1) in the requested interval
VarianceSample: Returns the variance for the StandardDeviationSample function
<[string]@node>: Variable or variables to retrieve. Users must inform a full name or names between single quotes and separated by commas
Result Fields
Name: Name of a variable or variables retrieved
Timestamp: Timestamp of data
Quality: Quality of data
Value: Value of data
Example
To return data from the RandomTags_Random1 variable in the period between 10:23 and 11:23 of 12/07/2020, with a timezone of -3 (minus three) hours and interpolated at every 5 (five) minutes, use the next statement.
SELECT Name, Timestamp, Quality, doubleval(Value) FROM
  EpmQueryAggregateFunction(-3, '2020-12-07 10:23:00', '2020-12-07 11:23:00',
  300000, 'Interpolative', 'RandomTags1')
EpmQueryAggregateFunction function
