EpmBrowseTypesFunction |
Returns a table with a list of all different types of objects found on an EPM Server.
SELECT * FROM EpmBrowseTypesFunction()
The resulting table contains only the TypeName field, which is the type of object found for which exists at least one item on the EPM Server.
To return all types of existing objects on an EPM Server, use the next statement.
EpmBrowseTypesFunction function
