EpmBasicVariablesView
Returns a table with a list of all existing variables of type BasicVariables on an EPM Server.
Syntax
SELECT * FROM EpmBasicVariablesView()
Result Fields
Name: Name of a variable
Description: Description of a variable
EU: Engineering unit configured in a variable
Example
To return data from variables with a BasicVariables type containing the expression "Elipse" in the Name field, use the next statement.
SELECT * FROM EpmBasicVariablesView() WHERE Name LIKE '%Elipse%'
EpmBasicVariablesView function
