EpmQueryRawData Stored Procedure |
Executes a query on one or more variables, searching raw data stored in the informed period.
EpmQueryByDate(
@timeZoneOffset float,
@startTime datetime,
@endTime datetime,
@valuesPerNode int,
@returnBound bit,
@nodelist nvarchar(max))
Where:
•timeZoneOffset: Timezone to consider. This value is a floating-point number ranging from -12 to 14
•startTime: Query's starting date. The date format depends on the database configuration
•endTime: Query's ending date
•valuesPerNode: Maximum number of records returned by this query. The value 0 (zero) in this parameter indicates that all query records must be returned
•returnBound: Indicates whether this query must return the value stored immediately before and after the informed interval
•nodeList: List with names of Data Objects to query. Users can also inform references and full paths on the Contextual Model, if they were contextualized
Usage example:
EXECUTE EpmQueryRawData 1, -2,
'01/15/2013 12:00:00', '01/31/2013 12:00:00',
0, 0, 'OpcTag04,OpcTag05'
In this case, the query returns all values from Basic Variables OpcTag04 and OpcTag05 from the second half of January.
NOTE |
Notice that the list with the names of variables to query uses a comma as a separator, without additional spaces. |
