<< Click to Display Table of Contents >> EpmQueryRawFunction Function |
Returns values as they were stored on the database, without applying aggregations.
EpmQueryRawFunction(
@timeZoneOffset float,
@startTime datetime,
@endTime datetime,
@valuesPerNode int,
@returnBound bit,
@node nvarchar(max))
Where:
•timeZoneOffset: Timezone to consider. This value is a floating-point number ranging from -12 to 14
•startTime: Query's starting date. The date format depends on the database configuration
•endTime: Query's ending date
•valuesPerNode: Maximum number of records returned by this query. The value 0 (zero) in this parameter indicates that all query records must be returned
•returnBound: Indicates whether this query must return the value stored immediately before and after the informed interval
•node: Name of the Data Object to query. Users can also inform a reference and a full path on the Contextual Model, if it was contextualized
Usage example:
SELECT Timestamp AS Time,
Value AS OpcTag05
FROM dbo.EpmQueryRawFunction(-2,_
'01/15/2013 12:00:00', '01/31/2013 12:00:00',
0, 0, 'OpcTag05')
AS EpmQueryRawFunction_1
In this case, the query returns the average values of Basic Variable OpcTag05 from the second half of January calculated with a one-hour window. Notice that the timeZoneOffset parameter was defined as -2 (minus two) and not -3 (minus three, GMT relative to Brasília) because in January there was a daylight saving time where data was stored.
