SUBSTRING
SUBSTRING
Returns a part of the String indicated in the @text parameter, starting at the position indicated in the @start parameter and with a maximum length indicated in the @length parameter.
Syntax
SUBSTRING(@text, @start, @length)
Parameters
@text: String to slice
@start: Initial position of the String to return
@length: Maximum length of the String to return
