EpmQueryAggregateFunction |
Returns data from one or more variables, comma-separated, informed in the @node parameter, according to the format defined by the aggregation function indicated by the @aggregateFunction parameter.
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(@timeZoneOffset, @startTime, @endTime, @sampleInterval, @aggregateFunction, @node)
•@timeZoneOffset: Timezone to consider. Possible values range between -12 and 14
•@startTime: Initial date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@endTime: Final date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@sampleInterval: Time interval used to calculate aggregation, in milliseconds
•@aggregateFunction: Name of the aggregation function to use. Possible values for this parameter are described on the next table
•@node: Variable or variables to query. Users must inform the full name or names between single quotes and comma-separated
Possible values for the @aggregateFunction parameter
Description |
AnnotationCount |
Informs how many annotations a variable has inside the sampling interval |
Average |
Calculates the average of data values with good quality inside the sampling interval defined in the @sampleInterval parameter |
Count |
Returns the number of data present in the sampling interval defined in the @sampleInterval parameter |
Delta |
Returns the difference between the first and last values with good quality inside each sampling interval |
DeltaBounds |
Returns the difference between the first and last values with good quality inside each sampling interval. It considers the Simple Bounding Values |
DurationBad |
Returns the time, in milliseconds, in which data had bad quality inside the sampling interval. Quality is defined based on the quality of data from interval's edges |
DurationGood |
Returns the time, in milliseconds, in which data had good quality inside the sampling interval. Quality is defined based on the quality of data from interval's edges |
DurationInStateNonZero |
Returns the total time, in milliseconds, in which a value remained different from 0 (zero) inside the sampling interval |
DurationInStateZero |
Returns the total time, in milliseconds, in which a value remained in 0 (zero) inside the sampling interval |
End |
Equivalent to the Interpolative function, but uses the original timestamp from the last value of the sampling interval |
EndBounds |
Equivalent to the Interpolative function, but uses the original timestamp from the last value of the sampling interval. It considers the Simple Bounding Values |
Interpolative |
Interpolates data from the queried interval, returning points according to the interval defined in the @sampleInterval parameter |
Maximum |
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval |
Maximum2 |
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval. It considers the Simple Bounding Values |
MaximumActualTime |
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the greatest value found occurred |
MaximumActualTime2 |
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the greatest value found occurred. It considers the Simple Bounding Values |
Minimum |
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval |
Minimum2 |
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval. It considers the Simple Bounding Values |
MinimumActualTime |
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the smallest value found occurred |
MinimumActualTime2 |
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the smallest value found occurred. It considers the Simple Bounding Values |
NumberOfTransitions |
Informs how many transitions occurred inside the sampling interval between values 0 (zero) and 1 (one) |
PercentBad |
Returns a percentage of time, relative to the time of the sampling interval, in which data had bad quality |
PercentGood |
Returns a percentage of time, relative to the time of the sampling interval, in which data had good quality |
PercentInStateNonZero |
Returns a percentage of time, relative to the time of the sampling interval, in which the value remained different from 0 (zero) |
PercentInStateZero |
Returns a percentage of time, relative to the time of the sampling interval, in which the value remained in 0 (zero) |
Range |
Returns the difference between the smallest and the greatest value found inside the sampling interval informed in the @sampleInterval parameter. Ignores bad quality values |
Range2 |
Returns the difference between the smallest and the greatest value found inside the sampling interval informed in the @sampleInterval parameter. Ignores bad quality values and considers the Simple Bounding Values |
StandardDeviationPopulation |
Returns the population standard deviation (n) in the requested interval. It includes the Simple Bounding Values |
StandardDeviationSample |
Returns the sampling standard deviation (n - 1) in the requested interval |
Start |
Equivalent to the Interpolative function, but uses the original timestamp from the first value of the sampling interval |
StartBounds |
Equivalent to the Interpolative function, but uses the original timestamp from the first value of the sampling interval. It considers the Simple Bounding Values |
TimeAverage |
Calculates the weighted average by time using the Interpolated Bounding Values method inside the sampling interval defined in the @sampleInterval parameter |
TimeAverage2 |
Calculates the weighted average by time using the Simple Bounding Values method inside the sampling interval defined in the @sampleInterval parameter |
Total |
Returns the sum of data from the sampling interval defined in the @sampleInterval parameter |
Total2 |
Returns the sum of data with good quality from the sampling interval defined in the @sampleInterval parameter |
Trend |
Interpolates queried data for a better visualization on charts |
VariancePopulation |
Returns the variance for the StandardDeviationPopulation function |
VarianceSample |
Returns the variance for the StandardDeviationSample function |
WorstQuality |
Returns the worst quality found in the interval specified in the @sampleInterval parameter |
WorstQuality2 |
Returns the worst quality found in the interval specified in the @sampleInterval parameter. It considers the Simple Bounding Values |
•Name: Name of the variable or variables queried
•Timestamp: Timestamp of data
•Quality: Quality of data
•Value: Value of data
To return data from variable RandomTags_Random1 in the period between 10:23 and 11:23 on 12/07/2020, with a timezone of -3 (minus three) hours and interpolated at every 5 (five) minutes, use the next declaration.
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(-3, '2020-12-07 10:23:00', '2020-12-07 11:23:00', 300000, 'Interpolative', 'RandomTags1')
